johanj
Oct 16, 2011Aspirant
Readynas Ultra rootfs entirely in NAND flash?
Hi, I consider buying a Readynas Ultra, but I am curious about the availability of the size of the built-in NAND flash. My key decision point is that _all_ software running on the NAS shall be stored...
TeknoJnky
Oct 16, 2011Hero
the nand flash is only used to store the firmware image, which is then installed to the drives upon factory default/initialization. Nothing runs from nand itself.
the device will not run without drives, the OS runs off the system partition, generally like a regular linux system.
