Glenn3193
Dec 08, 2023Aspirant
ReadyNAS Ultra4 - what can I do with it?
HI, I have a ReadyNAS Ultra 4 purchased in early 2013. I have been away for 2+ years (in the UK) and came back to find that I can not communicate with the NAS. Security issue I think. When I left it...
Glenn3193
Dec 29, 2023Aspirant
Thanks Stephen,
I have factory default reset the Ultra4. Raidar has found the unit, I can locate and browse (backup, c:, home, media). I can place files in backup and media, but cannot access c or home. I get the box "enter network credentials", but it comes up with the warning "access is denied" even before I enter credentials. I have input "admin" with "password" and "netgear1", but cannot access.
When I hit admin page, my browser comes up with:
"Secure connection failed
An error occured.......Peer using unspupported version of security protocol...
This website might not support TLS 1.2 protocol"
I have tried with 3 browsers (Chrome, Edge and Firefox). I am running Windows 11, software up to date.
Any ideas on how to access the Ultra4 to install what you recommend?
Appreciate your time on this, and your reply.
Best,
Glenn
Dec 30, 2023Guru - Experienced User
The first step is to make a temporary change to the FireFox settings so you can access Frontview. That change is to set security.tls.version.min to 1 (browse to about:config and search for the setting).
Once you can get into Frontview, you have two options:
The first option is to keep using 4.2.x firmware. If you do that, then you should first update the firmware to 4.2.31 (if it is running something older), and then install this add-on:
The second (and IMO better) option is to convert the NAS to run OS-6, using the instructions in the the 4th post of this discussion thread.
