nealjane
Jan 09, 2014Aspirant
READYNAS upgrade suggestions for OS-x
We currently use a readynas NV+ [v1] in our architectural practice for backup/storage of all our work. NV becoming increasingly un-useable with the Apple macs due to the cnidb errors over AFP we keep...
mdgm-ntgr
Jan 17, 2014NETGEAR Employee Retired
The 104 has a ARM CPU and 512 MB RAM and may struggle with large volumes (e.g. 4x4TB disks). The 516 has 4GB (that's 8x what's in the 104) RAM and a very fast Intel Ivy Bridge Dual-Core CPU. They are very different devices.
With a new setup it would be advisable to update to 6.1.5 (or later) and then after verifying the update is successful do a factory default (wipes all data, settings, everything). This will give you a clean setup on the new firmware.
