my-username
Aug 25, 2015Follower
ReadyNas User/Share Quotas
I have just purchased a ReadyNas 202. It seems great but there is one feature I feel it is missing, which I am sure was available on older low-end Netgear NAS drives which is user/share quotas. ...
mdgm-ntgr
Aug 25, 2015NETGEAR Employee Retired
This feature is already under consideration and one we would like to add. As StephenB mentioned stability is crucial. We will only add this feature when we are confident in its stability.
mdgm-ntgr
Aug 26, 2015NETGEAR Employee Retired
Share Quotas have been added in 6.4.0 Beta: https://community.netgear.com/t5/ReadyNAS-Beta-Release/ReadyNASOS-6-4-0-T112-Beta-2/m-p/975186#U975186
You can give the beta release a try or wait for the production release. Unless you really need the feature right now, seeing you have a 200 series unit I'd be inclined to suggest you wait.
