sc101hell
Jul 26, 2019Tutor
Readynas102 - control disk spin down and power through CLI
Hi, Just redoing my NAS and out of date with the software a little Before I go digging through files does anyone happen know, through CLI/ bash script how to control * Wakeon lan (ethtool?) *...
Jul 28, 2019Guru - Experienced User
sc101hell wrote:
Use case:
I'd like to control these settings through ssh commands so that I can change the behaviour of the system depending on use without using the GUI
You might find that your ssh setting changes won't survive reboot (the ReadyNAS application often rewrites configuration files then).
It'd be nice if there was a CLI interface to the ReadyNAS application that let you adjust these settings from ssh (but if there is, it isn't published).
sc101hell
Jul 28, 2019Tutor
Thanks Stephen.
I'll have a play but logically (hah) it must be storing that value for timout on disk musn't it? Or does it store those in the flash? e.g. are those settings still kept if you replace the disks?
- StephenBJul 28, 2019Guru - Experienced User
The values are stored on the disks. But the application has its own database of the settings, and it will sometimes recreate the usual linux files from the values in its database.
