Sportradio
Oct 09, 2025Aspirant
ReadyNAS104 no data after hotswap
Hi, I had the Volume: Volume data health changed from Degraded to Dead. I hotswapped the Volume 1 today, with an 8TB drive and now the other 3 drives are showing red, and the new drive is bl...
Oct 09, 2025Guru - Experienced User
Sportradio wrote:I had the Volume: Volume data health changed from Degraded to Dead.
Did this happen before you hot-swapped the drive?
Or was it a result of the hot-swap?
Sportradio wrote:now the warning is Remove inactive volumes #2,3,4.
Don't do that.
Sportradio
Oct 10, 2025Aspirant
Did this happen before you hot-swapped the drive? Yes
Or was it a result of the hot-swap? Hot swap
Don't do that. - unfortunately, I did.
- StephenBOct 10, 2025Guru - Experienced User
Once the volume is dead, it is too late to replace a drive. Still, sometimes data can be recovered (depending on exactly what happened).
Then you have lost your data. A data recovery service might be able to get it back.
FWIW, that message is confusing - it is only appropriate if you are wanting to create a new volume.
- SportradioOct 10, 2025Aspirant
Thanks Stephen
Can you point me in the right direction for a data recovery service?
- SandsharkOct 11, 2025Sensei
When StephenB says "don't do that", he means don't delete the volume via the UI, not don't physically remove them. Which are you saying you did? If all you did is remove the wrong drive, then your volume may be recoverable, especially if the NAS didn't even start to sync the new drive. You can get more info from the log .zip file. StephenB is good at helping you decipher the logs.
