Sportradio
Oct 09, 2025Aspirant
ReadyNAS104 no data after hotswap
Hi, I had the Volume: Volume data health changed from Degraded to Dead. I hotswapped the Volume 1 today, with an 8TB drive and now the other 3 drives are showing red, and the new drive is bl...
Sportradio
Oct 10, 2025Aspirant
Did this happen before you hot-swapped the drive? Yes
Or was it a result of the hot-swap? Hot swap
Don't do that. - unfortunately, I did.
Oct 10, 2025Guru - Experienced User
Sportradio wrote:Did this happen before you hot-swapped the drive? Yes
Once the volume is dead, it is too late to replace a drive. Still, sometimes data can be recovered (depending on exactly what happened).
Sportradio wrote:Don't do that. - unfortunately, I did.
Then you have lost your data. A data recovery service might be able to get it back.
FWIW, that message is confusing - it is only appropriate if you are wanting to create a new volume.
