Sportradio
Oct 09, 2025Aspirant
ReadyNAS104 no data after hotswap
Hi, I had the Volume: Volume data health changed from Degraded to Dead. I hotswapped the Volume 1 today, with an 8TB drive and now the other 3 drives are showing red, and the new drive is bl...
Sportradio
Oct 13, 2025Aspirant
Hi,
I have just turned the unit back on with all 4 original drives in place.
This is what I see.
Oct 14, 2025Guru - Experienced User
Sportradio wrote:I don't think XRAID was enabled. It was just RAID5
XRAID was enabled (and still is). The green stripe on the XRAID control tells us that.
Sportradio wrote:This is what I see.
Download the full log zip file from the logs page.
If you can't interpret what it says, you can put it into cloud storage and send me a link via private message (PM). Make sure the permissions are set so anyone with the link can download. You send a PM using the envelope icon in the upper right of the forum page.
Best not to post the link publically, as there is some privacy leakage when you do that.
Sportradio wrote:Hi, the drive was originally degraded. but now it looks dead
You are using drive and volume interchangably - which creates some confusion.
"Drives" are the physical drives. You hotswapped the first drive.
"Volume" is the file system that spans all your drives. The volume is what was degraded (and is now dead/inactive).
