Kryptonic
Feb 08, 2020Aspirant
ReadyNAS212 Permission problem on SMB shares for local users
Hi I'm currently adjusting all the user permissions on my ReadyNAS shares but I'm unable to give read/write access a specific user, only to the default admin user. I want to be able to access the...
- Feb 09, 2020
Kryptonic wrote:
What does this "folder group" mean?Folder Owner and Folder Group refer to the owner and group for the share at the top of that page,
FWIW, enabling Everyone access to read/write in the file permissions is safe, as the network access is enough to manage access to the share. Also, file permissions (and ownership) can be changed from Windows, so it's best practice to use network access anyway.
The only case where you actually need to manage the file permissions more aggressively is when you want to deny access to specific files and folders in the share.
Feb 09, 2020Guru - Experienced User
Kryptonic wrote:
Let's say I have only 2 users: the default "admin" user + a "test" user and also a share called ""Dropin".
Both users have "read/write" checked under "network access" (smb protocol) and "file access" (security tab).
For some reason only the admin user can access the Dropin share, I tried it on several Win 10 PC's (same problem).
This should work (it would also work if the "test" user's group also has read/write access).
Though I recommend allowing Everyone read/write access in file access - and only use network access to manage permissions. So try changing that, and after applying the change, use the reset control to reset all the file permissions in the share.
