Kryptonic
Feb 08, 2020Aspirant
ReadyNAS212 Permission problem on SMB shares for local users
Hi I'm currently adjusting all the user permissions on my ReadyNAS shares but I'm unable to give read/write access a specific user, only to the default admin user. I want to be able to access the...
- Feb 09, 2020
Kryptonic wrote:
What does this "folder group" mean?Folder Owner and Folder Group refer to the owner and group for the share at the top of that page,
FWIW, enabling Everyone access to read/write in the file permissions is safe, as the network access is enough to manage access to the share. Also, file permissions (and ownership) can be changed from Windows, so it's best practice to use network access anyway.
The only case where you actually need to manage the file permissions more aggressively is when you want to deny access to specific files and folders in the share.
Kryptonic
Feb 09, 2020Aspirant
Hi StephenB
If I give everyone read/write access in file access then it works, I think I will use this as a workaround thank you.
I also found another method, I don't need to give everyone read/write access (in file access).
If I uncheck read/write for everyone and check it for the "folder group" then my test user also has access to the Dropin share (on condition read/write access is also checked for the test user).
I read somewhere it's linked to guest user by default, I don't see how this affects my test user access rights (which is member of the "users" group).
Feb 09, 2020Guru - Experienced User
- KryptonicFeb 09, 2020Aspirant
Thanks for the clear explanation.
I changed my permissions following the general rules/steps and it works.I think my problem is solved, this topic can be closed thank you.
