JB4204
Apr 25, 2021Aspirant
ReadyNAS314 - Access Extremely Slow
ReadyNAS 314 - F/Ware 6.10.4 hotfix 1 - 4 x 4TB WD Red in XRAID This has been working fine for a number of years - until the past week or so. Network drives mapped from 4 different Win10 PC's...
Apr 25, 2021Guru - Experienced User
JB4204 wrote:
Log files don't indicate any errors and no disk errors shown.
Did you look in the log zip, or just on the screen? There's a lot more in the log zip.
Sluggish performance is generally linked to performance issues with
- disks
- network or
- NAS CPU/Memory
looking for disk and btrfs errors in system.log and kernel.log can be helpful (if you haven't done that already).
Looking at tx and rx packet stats in network-settings.log will give you clues on the network performance. One thing to try is grabbing the log files before and after a transfer test, and compare the stats.
On CPU/Memory, one thing to try is disabling your apps (and antivirus and file search) and see if that makes any difference. You can also enable ssh, and run top.
- JB4204Apr 25, 2021Aspirant
Ah right, OK, thanks for the info - yeah, was just looking at logs on the NAS - have now downloaded and will check files you mentioned
