hm_123
Jan 30, 2017Aspirant
ReadyNas314 file restore os 6.6.1
ReadyNas 314. upgarded to os 6.6.1 today. i then had to resore a file. I click restore and nothing happened. The network share show offline. but the orther share are online. Can any1 help? ...
Jan 30, 2017Guru - Experienced User
You are doing this from windows?
hm_123
I went into the nas via web browser. loged into my readyNas.
and it came up update nas OS to 6.6.1. i clicked yes. let it update.
i then when into nas and selete a file to restore and nothing happened. so waited and restarted nas.
then i check the shares via windows 7.
my other shares are showning online but execpt one share which the file was in. that is showing offline.
I have restarted NA twice and no luck. :(
- StephenBJan 30, 2017Guru - Experienced User
hm_123 wrote:
i then when into nas and selete a file to restore.
So you were restoring the file from the admin web ui? I'm checking because you can also do this from windows by right-clicking on the file and selecting previous version.
I think this is the real problem. The restore might actually have worked. First try going into the share settings, and try turning SMB off for that share, and then turn it on again.
After that, try entering \\nas-ip-address\sharename or \\nas-name\sharename in windows file explorer, and see if you can access the share (using the real ip address or hostname of course).
You can also try accessing the full data volume using NAS admin credentials. Open CMD and enter
net use * /delete
net use t: \\nas-ip-address\data /user:admin nas-admin-password
using real values for the italicized placeholders. The first command deletes any open network sessions (which will disconnect your other shares). The second mounts the NAS data volume as drive letter t. "data" is the default data volume name, if you manually created the volume you might have a different volume name you'll need to use.
Then you can browse through drive T and see if the restored file is in there.
