JordanThompson
Apr 11, 2020Aspirant
ReadyNASs 314 privacy error when connecting with Chrome
Two of my disks died and for some reason I got no warning. Luckily I had everything backed up! I wound up completely reinstalling the system and installed 4 new drives. In the process, I have n...
- Apr 13, 2020
So here is the solution...
I was trying to log into https://myNas which was giving me fits on Chrome. All I had to do was go to http://myNas, accept the certificate, and now I can access it normally. Sheesh, what a PITA!
thank you everyone for your suggestions.
JordanThompson
Apr 12, 2020Aspirant
I've replaced the SSL certificate.
Chrome is not having any problem finding the ReadyNAS so it's not a DNS problem.
Believe me, I have Googled for this.
Apr 12, 2020Guru - Experienced User
- JordanThompsonApr 12, 2020Aspirant
StephenB wrote:
JordanThompson wrote:
I've replaced the SSL certificate.Did that resolve the problem?
No, that was the first thing that had done.
- StephenBApr 12, 2020Guru - Experienced User
Are you saying that the problem occured right after you replaced the SSL certificate???
FWIW, I did a fresh install on one of my own NAS last week, and didn't see this.
No, I encountered the problem, then Googled around and changed the SSL certificate. FWIW, it is working more or less as expected in Safari.
