guycarr360
Jan 04, 2012Aspirant
Rebuild x raid
Hi all,
Have a NV+ *brand new), which has 2 x 1tb discs installed, from another thread i tried to recover some data from another drive without sucess.
This drive is now away for recovery, however drive light 3 flashes, and i cant dismount or loose the drive.
I need to re sync the 2 new drives left in the unit.
Any help on how to loose drive 3 appreciated.
- mdgm-ntgrNETGEAR Employee RetiredBackup your data and then do a factory default (either via System > Update > Factory Default in Frontview or via the boot menu: http://www.readynas.com/kb/faq/boot/how_do_i_use_the_boot_menu)
- guycarr360AspirantThanks for your help, factory default reload did the trick!!!
