Gary86
Jun 12, 2020Follower
recovering files- dosattrib
hi
I have an RND2110 v2 which has given many years of trusty service.
But, now it's failed, it's a power issue- started by failing to boot up in the morning (I had it set to turn off overnight) a couple of times and then wouldn't power up at all.
So, I have a USB drive back up of most of my data, but it's a few days out of date and I would like to recover everything.
I've purchased a new RN212 to set up. I also purchased a USB to 3.5in SATA converter, so that I can plug my drives into the PC. Using R-Linux I have got one of the drives and scanned it and I'm recovering files, which all seems to be working ok.
My problem:
When I recover the files I'm also getting a 2nd file with same name with a .$ea.user.DOSATTRIB suffix
eg: in the folder:
<file name>.png.$ea.user.DOSATTRIB
I have tried deleting one of the dosattrib files from a recovered folder and it seems to make no diifference to the original file, so I don't think I need it. So, assuming that os the case, is there a way to get rid of them all or to stop them being created?
I'm reasonably tech savvy, but no expert!
Thanks for reading all that, and any hep you can offer is greatly appreciated,
Gary
Those files store the Windows file permissions for the main file. I do suggest getting rid of them.
After you restore everything, you should be able to search for all *.dosattrib using the file explorer search bar, select all the files with cntl-a, and then delete them all by pressing the delete key.
1 Reply
