neonshades
Jul 13, 2016Tutor
Recycle bin on RN104
Please give me an easy answer.... and please only answer if you know (no guesses). is there a tick box to enable the recycle bin on the RN104? My ReadNas NV+ V2 has a tick box to enable th...
BrianL2
Jul 13, 2016NETGEAR Employee Retired
Hi neonshades,
Welcome to the community!
The answer to your question can be found on this thread.
Kind regards,
BrianL
NETGEAR Community Team
- neonshadesJul 13, 2016Tutor
Hi BrianL,
Unable to follow your thread. Will not accept my login.
Nor will it send me a password update.
Robert....
- StephenBJul 14, 2016Guru - Experienced User
Must be a cut-and-paste error on Brian's part.
You could look here: https://community.netgear.com/t5/Using-your-ReadyNAS/Can-Recycle-Bin-be-enabled-for-CIFS-and-OS-6-1-2-on-a-314/m-p/856712/highlight/true#M26776
and perhaps read through the posts after the highlighted thread as well. The process will require some knowledge of linux.
Though I find Snapshots to be a good alternative. With snapshots enabled, you can roll-back to older versions of the share, and if you right-click from windows on a file you can see/access previous versions. If you right-click on the folder and access previous versions, you can select deleted files and restore them. It's not exactly the same as the recycle bin, but it is similar.
- BrianL2Jul 14, 2016NETGEAR Employee Retired
Hi neonshades,
Sorry, I made a mistake with the link I used in my previous post (I already updated it). Anyway, StephenB already gave an introduction on how Snapshots work on the new OS 6 systems. Just let us know if you have further questions.
Kind regards,
BrianL
