neonshades
Jul 13, 2016Tutor
Recycle bin on RN104
Please give me an easy answer.... and please only answer if you know (no guesses). is there a tick box to enable the recycle bin on the RN104? My ReadNas NV+ V2 has a tick box to enable th...
Jul 14, 2016Guru - Experienced User
Must be a cut-and-paste error on Brian's part.
You could look here: https://community.netgear.com/t5/Using-your-ReadyNAS/Can-Recycle-Bin-be-enabled-for-CIFS-and-OS-6-1-2-on-a-314/m-p/856712/highlight/true#M26776
and perhaps read through the posts after the highlighted thread as well. The process will require some knowledge of linux.
Though I find Snapshots to be a good alternative. With snapshots enabled, you can roll-back to older versions of the share, and if you right-click from windows on a file you can see/access previous versions. If you right-click on the folder and access previous versions, you can select deleted files and restore them. It's not exactly the same as the recycle bin, but it is similar.
BrianL2
Jul 15, 2016NETGEAR Employee Retired
Hi neonshades,
Sorry, I made a mistake with the link I used in my previous post (I already updated it). Anyway, StephenB already gave an introduction on how Snapshots work on the new OS 6 systems. Just let us know if you have further questions.
Kind regards,
BrianL
NETGEAR Community Team
- neonshadesJul 15, 2016Tutor
Hi BrianL,
Thanks for the help but snapshot is not what I needed. Guess the simple answer is no, the recycle bin tick box has been removed from the RN104 operating system.
Shame really.
Robert....- BrianL2Jul 17, 2016NETGEAR Employee Retired
Hi neonshades,
I apologize if the said feature you are looking for is unavailable on the new OS 6 system. If you want this feature to be added again, I suggest that you post another thread on this board.
Kind regards,
BrianL
NETGEAR Community Team- davexyzJul 20, 2016Aspirant
From the original post of JMehring 20 November 2013
putty and ssh required
1) create file addons.conf as below
\etc\frontview\samba\addons\addons.conf
I think you have to create the addons directory as well.
2) then edit addons.conf, I use vi, to include the shares that you wish to have Recycle Bin activated for (include the square brackets)
[name of your share 1]
vfs objects = recycle
recycle:repository = Recycle Bin
recycle:keeptree = yes
recycle:versions = no[name of your share 2]
recycle:versions = no3) Save file. As you can see you can choose the name of the "bin" . leave putty window open
4) to "activate" go to frontview interface on the nas and the share window
toggle a property of the share for example ftp on to off. this reloads the config file to include addons.conf
5)then in putty window type:
testparm
this should list your shares and show the recycle:parameters for the shares defined
6) close putty
I did this and I was a complete linux/ssh novice.
If you install/update firrmware on the nas check that this file exists, factory reset obviously wipes this file
It works for usb attached drives etc just use the drive name ie USB_HDD_1 etc
for very large >5Tb usb drives there is also a bit of a fidddle required on some NAS' due to the adding of the addons.conf file to the "main config file. If it does not load then post and I can give pointers on how to correct.
