Korky
Dec 21, 2019Aspirant
Remove inactive volumes after clearing root usage is 91%
Hi, Wondering if somene could help me with my readynas issue. The device was complaining about volumn 30% remaining for a few days, which I ignored becuase the frontview showed I had 3TB free. ...
Korky
Log files upoad to fileshare :
Google Drive
<redacted>
Dropbox
<redacted>
- StephenBDec 21, 2019Guru - Experienced User
I redacted the log download links - logs shouldn't be posted publicly.
Instead send a private message (PM) to one of the mods - JohnCM_S or Marc_V - asking them to review the logs. Post the download links in the PM. You send a PM using the envelope icon in the upper right of the forum page.
- JohnCM_SDec 21, 2019NETGEAR Employee Retired
Hi Korky,
It appears that the NAS detected a file system issue which caused the volume to go offline.
Dec 21 11:38:07 medellin kernel: BTRFS error (device md127): qgroup generation mismatch, marked as inconsistent
Dec 21 11:38:07 medellin kernel: BTRFS error (device md127): parent transid verify failed on 20487719354368 wanted 409344 found 409342
Dec 21 11:38:07 medellin kernel: BTRFS warning (device md127): failed to read log tree
Dec 21 11:38:07 medellin kernel: BTRFS error (device md127): open_ctree failedDo you have a back up of your data?
If you do not have a backup, it will be best for you to contact NETGEAR Support because there are BTRFS errors and data is involved. They will check if there still some corrective changes that can be done via backend access or if data recovery is needed.
If you do have a backup, another option is to reset the NAS to factory default then recover from backup.
Regards,- KorkyDec 22, 2019AspirantThank John,
Will reinstall of the OS not resolve the issue or
Adding additional disk drive?Will that make it matters worse?
No, I don't have backup of the data. The the data is mostly media which I can live without. However, I do have a few GB of family photos that I would like to recover if I can.
Thanks again
