richbeale
Dec 07, 2019Aspirant
Removed drives, reinstalled and keeps wanting to wipe the drives
Hi I have a very old ReadyNas Duo. I removed a 4TB drive from another RN102 drive as I stupidly installed a new 8TB drive without realising it would only format to 4TB as I had a 4TB drive in...
richbeale
thanks for the reply
Unfortunately I only have macs in the house, anything on the mac I can use, i'll go grab a USB dock for the drive tomorrow.
Thanks
Dec 07, 2019Guru - Experienced User
Also this reply: https://community.netgear.com/t5/New-ReadyNAS-Users-General/existing-readynas-Duo-drive-in-same-machine/m-p/1833683#M38983
I don't own a Mac, so I can't offer much advice. You could try this, but it is not free: https://www.r-studio.com/data_recovery_macintosh/
You can download it for free though, and see if it finds your data before you purchase. So you could
- confirm that R-Studio sees your data (w/o purchase)
- see if the Duo boots ok with the remaining disk
- purchase R-Studio only if it doesn't.
- Jul 15, 2018Retired_Member
