Joe-9O
Aug 01, 2019Aspirant
Replaced 4 NV+ RND4000 500GB with 2TB disks but there is no capacity increase
Hello, I've replaced 4 x 500Gb disks with 4 2Tb disks (1 at a time). However the volumes did not get expanded to reflect the added physical storage. My understanding is that the volumes should ...
Aug 02, 2019Guru - Experienced User
Try rebooting the NAS and see if expansion starts.
- Joe-9OAug 02, 2019Aspirant
Thank you Stephen,
I tried that with no luck.
I also tried "Resync Volume"
And I have presently rebooted with the "Check and Fix Quota" option selected.
It is presently offline as it is doing this check.
Thank you - Avinash
- StephenBAug 02, 2019Guru - Experienced User
If that fails to solve it, then try enabling journaling and disabling disk spindown. Then try rebooting with "check and fix Quota" a second time.
Thank you Stephen!
I will try that if the current "fix quota" reboot does not work.
