grintstick
Jun 21, 2017Aspirant
Replacement disk not recognised Readynas nv+ RND4000
I had 2 x 2TB drives in my nv+. One of the drives failed so I replaced it with a new drive. (Made sure its on compatibility list.) It's supposed to be hot swappable, but: - When I place the new d...
grintstick
Jun 22, 2017Aspirant
I'm using a Seagate Barracuda
Code:
ST2000DM006 Barracuda
https://www.amazon.co.uk/gp/product/B01ICLGJF8/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Thanks...
Jun 22, 2017Guru - Experienced User
Can you try testing it again with seatools in a PC? There's a destructive "write zeros" test that might be more useful than the normal long SMART test.
- grintstickJun 22, 2017Aspirant
Yeah I can try that.
If that comes out ok, do you reckon my NAS is just old and needs replacing? Can't think what else it could be...
- StephenBJun 22, 2017Guru - Experienced User
Your NAS is old, and you should be planning a replacement. Current models are much faster, have more features, and will be fully up to date on security patches.
You can then (assuming we get past this problem) repurpose your NV+ as a backup to the new NAS.
FWIW, my own NV+ is still working, and I do use it to back up some shares on my RN526x.
The drive is still the most likely.
What firmware are you running? One option is to upgrade the firmware to 4.1.16 (if it's not already), offload the data to backup, and try doing a factory reset. But if the drive isn't playing nicely with the NAS, that won't help.
You could also exchange the DM for an WD20EFRX (Western Digital "Red") or an ST2000VN004 (Seagate "Ironwolf"). Both are better choices for your NAS, although they aren't on the HCL.
Note: Netgear hasn't touched that HCL for some years, so it is not the best guide anymore. NAS-purposed drives (the two model lines listed above) are the best option if you are looking for consumer-grade drives. They are designed for NAS use, and have features like TLER and vibration management which normal desktop drives don't have.
Thanks for the replies -
I gave the drive to my engineering dept at work who are pretty good and they said the drive was fine - although I could of course do the extended check as suggested.
I'm tempted though just to return this one back to Amazon and get a WD20EFRX (Western Digital "Red") or an ST2000VN004 (Seagate "Ironwolf"), as suggested - just to shortcut that process.
I have already upgraded firmware to 4.1.16 with no solve. I guess if the above doesn't work, they'll I'll offload the whole lot and try a factory reset, or just get a new NAS or Thunderbolt Raid. I have found the nv+ pretty slow - I'm temped if I get a new one to get a thunderbolt raid so I can use that for editing photos in Lightroom more successfully and hopefully also use it as a media server for streaming movies and so on. Unless you would recommend a straight NAS over that?
Thanks again...
