Pongo1
Sep 03, 2020Tutor
Replacement disk? Seagate ST2000DL003-9VT166 dead
My ReadyNAS Duo is reporting Disk 1 "dead", so I need a replacement asap. Searching for "Seagate ST2000DL003-9VT166" produces a plethora of differing model/spec numbers, and/or what seems to be u...
AllDueRespect
Feb 17, 2021Initiate
Question... I could not figure out if one of them was in fact damaged and whether you repaired it.
Having two of same model, did you try swapping the boards?
I have same exact model (9Vt166-301) with Firmware CC32 Date "11321".
I am looking for a donor card to see if this will work. So my question... did you end up replacing them? Are you willing to sell one of them to me? To say the thruth, I am not interested on keeping the drive, just trying to see if I can recover the data as at some point i put my collection of family photos. I am looking at older ones being sold online.
That was some 9 years ago, I have been holding to the HD and found it in the end of a drawer.... maybe it is time to take a look at it.
Best regards,
LuisG
Pongo1
Feb 18, 2021Tutor
Hi LuisG,
I didn't try to repair the disk drive itself, but just bought two new matching disks (one of the models as recommended by StephenB above), and used them to copy the data from my one good 9VT166.
I think I've since destroyed both of the old 9VT166.
Given the price of 9VT166 (even as obsolete stock), you might be better off just going to a data recovery company. If its the board thats faulty, they'll probably have a method of reading the disk directly.
Good luck (I have most of my honeymoon photos stuck in a corrupted phone memory!).
