GRS1
Mar 28, 2016Tutor
Replacement fan for ReadyNas 600
I need to find a replacement fan for the readynas 600, as the one inside has gotten loud. The original fan was a Jun Yih Shyang Ent. Co. Ltd jhd-03009a12, which I can't find anywhere. An apparen...
mdgm-ntgr
Mar 28, 2016NETGEAR Employee Retired
Not sure about which 3rd party fan replacements are available for the Infrant ReadyNAS 600, but considering the age of the ReadyNAS 600 (you've probably had it over 10 years) it might be about time to consider getting a new ReadyNAS.
- GRS1Mar 29, 2016Tutor
I have had it over 10 years, and it continues to serve its purpose perfectly fine. I don't really need a new one for what I use it for.
I do also have an 18TB Pro6 dedicated to offline tivo storage. Thats alot of TV!
But thanks for reading.
For now its working with the crossflow unplugged disks at 114, cover off.
Still would like to find a substitute fan for the original.- StephenBMar 29, 2016Guru - Experienced User
I've never owned a 600, but am wondering if this would fit: http://www.amazon.com/Dyantron%C2%AE-CF-003-Crossflow-Servers-Enclosures/dp/B009SEN4Q6
It's 5 mm longer, and is noisier. It has a 3-pin connector.
- GRS1Mar 31, 2016Tutor
It looks like this would work assuming the extra 5mm is split equally on both sides of the length. If its all on the left, it might be a tight fit.
Assuming of course the screw holes line up. (I would assume its a standard.)
The original does have a 3 pin connector, so that is probably fine.
The other big question is if the cord is long enough.
Thanks.
