nabed4t
Jan 04, 2020Aspirant
Replacement power cable
Hello, The power cord for my Netgear RND-4000-200AJS NAS was recently damaged and for the life of me I'm unable to find a replacement cable in Australia. I can fine some on Ebay but the postage is a...
Jan 05, 2020Guru - Experienced User
nabed4t wrote:
Hello,
The power cord for my Netgear RND-4000-200AJS NAS was recently damaged and for the life of me I'm unable to find a replacement cable in Australia. I can fine some on Ebay but the postage is around $80 and the cable itself is $70.
This is an NV+ v2 NAS with an external power adapter, correct?
Are you talking about the cable that runs between the power adapter and the wall outlet? Or are you talking about the entire power adapter?
The power cable between the power adapter and the outlet isn't anything special. I believe this one would work: https://www.amazon.com.au/Delippo%C2%AE-Computer-Monitors-Projectors-Printers/dp/B07D8KNF23
- nabed4tJan 05, 2020AspirantHey,
Correct, it is a NV+ v2 NAS.
The part I'm after is the 4 PIN connection from the back of the NAS to the power brick. Unfortunately, it looks like Netgear have used a proprietary connection.
Thanks again for the reply.- SandsharkJan 05, 2020Sensei
It has been a while since I've seen one, but I do not believe it's a proprietary connector, but is a somewhat common for 12V supplies >5A, though there does not seem to be universal agreement on polarity. It's the same as for the current 4-bay models, for which I see supplies on eBay for under $30US. It's about $35 on Amazon. I have no idea on shipping to Australia. My only concern is that the sellers seem to have "cleverly" covered up the output rating, so I wonder if they are a bit underpowered.
