JPP314's avatar
JPP314
Replacing a ReadyNAS Pro
I have an old RNDP6350 (6 bay ReadyNAS Pro Business Edition) and I'd like to know if there's any way to replace the box with a newer 6-bay model and move my 6 drives with data onto the new system without doing a backup and restore. I'm running RAIDiator 4.2.31 in X-RAID2 mode.
Jonathan
  • Retired_Member's avatar
    Retired_Member
    Hi JPP314, as the newer systems RN426, RN526 and RN626 are based on different hardware and run different firmware, I fear the answer is negative.
    However, without having a good backup of your data, I would not even dare to try something like you are asking for. So, if you decide to create the backup anyway or have it already you could follow the "classic" approach:
    a) backup data from old box
    b) insert old disks into new box and format them
    c) create the volume according to the RAID-flavour you prefer
    d) restore the data to new box.
    Kind regards
  • No, there is not.  There is a procedure for recovering data from an Pro6's drives using an OS6 based system and moving the data to external storage for those with a Pro6 that has died, but there is no way to move the drives over with data intact and continue to use the NAS in that configuration.
    • StephenB's avatar
      If the Pro is still functioning well, then I suggest getting new disks for the new NAS, and repurposing the Pro as a backup of the new NAS. You could use fewer (but larger) disks in the new one.
      The Pro can also be converted to run OS-6, though the process does require a factory reset and a restore from backup.  Once converted, you could directly migrate the disks to a new NAS in the future.
      • Sandshark's avatar
        Sandshark
        Sensei
        If you decide to keep the ProBE and convert to OS 6, updrading the processor and memory will make it quite a bit faster.  Instructions for doing so are on the forum, though Googling usually works better to find it than the forum's search function.
ProSupport for Business
