SSkwarkowski's avatar
SSkwarkowski
Replacing all discs in unit will not increase space
Thanks for reading. Hopefully someone can help me out. Unit Info: ReadyNAS NV+ 1GB Ram Firmware: RAIDiator 4.1.14 [1.00a043] Volume C: Online, RAID Level 5, 4 disks, 95% of 2760 GB used   <---...
  • StephenB's avatar
    Oct 31, 2016
    SSkwarkowski wrote:
    I dont ever recall being given any options to choose which raid setup I wanted originally (with the 1TB drives). I just did the factory reset and let it do its own thing.
    What happens then depends on the details.
    With your NAS there is a ~5 minute window after you start the reset where you choose a RAID mode.  You do that by clicking on the setup button in the the RAIDar application.  After you pick a RAID mode you'd go continue with the normal NAS setup.  Since you definitely are using flexraid, I think that must be what you did.
    If you don't use RAIDar to set up the NAS (for instance if you just access the NAS via your browser), or the 5 minute window ends, then the system will just use the default XRAID.
    FWIW, OS 6 handles this differently.
ProSupport for Business
