SSkwarkowski
Oct 30, 2016Aspirant
Replacing all discs in unit will not increase space
Thanks for reading. Hopefully someone can help me out. Unit Info: ReadyNAS NV+ 1GB Ram Firmware: RAIDiator 4.1.14 [1.00a043] Volume C: Online, RAID Level 5, 4 disks, 95% of 2760 GB used <---...
- Oct 31, 2016
SSkwarkowski wrote:
I dont ever recall being given any options to choose which raid setup I wanted originally (with the 1TB drives). I just did the factory reset and let it do its own thing.
What happens then depends on the details.
With your NAS there is a ~5 minute window after you start the reset where you choose a RAID mode. You do that by clicking on the setup button in the the RAIDar application. After you pick a RAID mode you'd go continue with the normal NAS setup. Since you definitely are using flexraid, I think that must be what you did.
If you don't use RAIDar to set up the NAS (for instance if you just access the NAS via your browser), or the 5 minute window ends, then the system will just use the default XRAID.
FWIW, OS 6 handles this differently.
SSkwarkowski
I simply did a factory reset. I though X-Raid was set on factory reset? Im not even sure how or if Flex Raid is there.
It simply says this:
| Volume C: | Online, RAID Level 5, 4 disks, 95% of 2765 GB used |
- SandsharkOct 30, 2016Sensei
SSkwarkowski wrote:I simply did a factory reset. I though X-Raid was set on factory reset? Im not even sure how or if Flex Raid is there.
XRAID should be the default after a factory default if you let it time out rather than access it via RAIDar and specify what configuration to use. Are you sure you didn't accidently select RAID5 instead of XRAID, perhaps not recognizing the difference at the time?
