SSkwarkowski
Oct 30, 2016Aspirant
Replacing all discs in unit will not increase space
Thanks for reading. Hopefully someone can help me out. Unit Info: ReadyNAS NV+ 1GB Ram Firmware: RAIDiator 4.1.14 [1.00a043] Volume C: Online, RAID Level 5, 4 disks, 95% of 2760 GB used <---...
- Oct 31, 2016
SSkwarkowski wrote:
I dont ever recall being given any options to choose which raid setup I wanted originally (with the 1TB drives). I just did the factory reset and let it do its own thing.
What happens then depends on the details.
With your NAS there is a ~5 minute window after you start the reset where you choose a RAID mode. You do that by clicking on the setup button in the the RAIDar application. After you pick a RAID mode you'd go continue with the normal NAS setup. Since you definitely are using flexraid, I think that must be what you did.
If you don't use RAIDar to set up the NAS (for instance if you just access the NAS via your browser), or the 5 minute window ends, then the system will just use the default XRAID.
FWIW, OS 6 handles this differently.
SSkwarkowski
This is all it says:
https://www.dropbox.com/s/j6s4haz0amo3rbo/Untitled15.png?dl=0
Oct 31, 2016Guru - Experienced User
It does. But the screen shot should say X-RAID....
Try doing another factory reset (perhaps from the admin ui).
