BernyB
Feb 22, 2017Tutor
Replicate config backup
Hi, The Replicate portal should really really really have an option to save or reload a configuration file because on any problem, we have to enter backup jobs manually with the exact same names, ...
JennC
Feb 23, 2017NETGEAR Employee Retired
Hello BernyB,
Your idea to improve the quality and functionality of the product is very much appreciated, we thank you for sharing and interest in this. You may also post suggestions and ideas at the Idea Exchange board. Adding kudos to the ideas will help as development team will be reviewing the post that has the most kudos for considering it to add to the product's future functionality.
We appreciate your contribution to the community!
BernyB
Jul 12, 2017Tutor
Hi,
I lost my Replicate config again, because it stopped after an extended power outage and I had to go to the remote location to deregister®ister the replicate service ONCE AGAIN. Then I have to rebuild all my backup jobs ONCE AGAIN because the service cannot remember them.
Is there any way to make that interface more RELIABLE ? Should I use an other method to backup my main NAS ?
:robotmad:
Bern
- Marty_MJul 13, 2017NETGEAR Employee Retired
Hello BernyB,
There is no option to backup the configuration of the backup job on the Readynas Replicate server. You may want to raise the concern to our Idea Exchange board, if it does get a lot of kudos the engineering might review and might consider adding the feature in the Replicate server.
Marty_M
NETGEAR Community Team- Marty_MJul 16, 2017NETGEAR Employee Retired
Hello BernyB,
We’d greatly appreciate hearing your feedback letting us know if the information I’ve provided has helped resolve your concern or if you need further assistance. If ever your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Marty_M
NETGEAR Community Team- BernyBJul 17, 2017Tutor
Hi Marty_M,
With all due respect, I do not think that JennC's proposal is a response that deserves to be accepted as a solution.
Cordially
