mtakacs
Sep 21, 2011Aspirant
request: Capacity Calculator
I'e been doing searches about how to calculate capacity for my readyNAS and I think I understand it, but it's not nearly as much fun as: http://www.drobo.com/calculator/4-bay/index.php Just look...
PapaBear1
Jan 18, 2012Apprentice
It's still easy. If you have single redundancy, you remove one of the largest drives. So in the case 4x1.5TB drives and 2x3TB drives, it is 4x1.5x.93=5.6TB and 1x3TBx.93=2.8TB which equals 8.4TB. If you were 3 and 3, it would be 3x1.5TBx.93=4.2TB plus 2x3TBx.93=5.6TB for a total of 9.8TB. In the case of Dual redundancy you must have 4 of the larger drives for the second layer to come in, so in the either 4x1.5TB and 2x3TB or 3 and 3 you would have 4x1.5TBx.93=5.6TB.
Incidentally, the link above no longer works. I just put the numbers in Excel and let it do the calculation. Just remember to take out the 1 or 2 largest drives.
Have you watched this? http://www.readynas.com/?cat=53
