Stanman130
Apr 02, 2015Guide
Request for OS6: Bacula
There used to be a Bacula Add-on for the older ReadyNAS versions, but it doesn't appear to be available for OS6. Would it be better to install it directly as a Linux package? Or is there an add-on pac...
Apr 02, 2015Guru - Experienced User
You could alternatively use the built-in backup (perhaps rsync).
