fremske
Dec 05, 2013Guide
Request for OS6: Serviio 1.3.1 (Media Streaming Server)
Hi add-on developers, I have a community request to make Serviio (link: http://serviio.org) available for the ReadyNAS OS6 platform both ARM and x86. I had serveral NAS systems in the past and tried...
saketb
Dec 23, 2013Aspirant
super-poussin wrote: 1.4.0 will be in a few minutes in the dropbox with a special ffmpeg build for serviio
let me know how it goes :)
Merry Christmas
First of all, a big Thank you for compiling the new version of Serviio.
I just downloaded and installed the newly build Serviio version to my RN104 and guess what...
My Samsung TV plays, "flac" audio files. I unchecked the "Transcoding" option and tried to play, but it fails. So, this makes it certain that RN104 is transcoding on-the-fly and streaming the audio files to my TV.
On the other hand my Panasonic Blu-Ray player plays "flac" files even without transcoding option enabled, so certainly it plays flacs natively.
Issues I found...
Playlists - I shared a folder named "playlists" with audio option enabled containing a .pls file. The .pls file is seen under the "Playlists" folder on my TV, but it lists only partial music files and not all. There is some issue here!!!
Online Content - I shared an online radio under "Live Stream" and checked the "Stream URL" and it showed in green. But when played thru my TV/Blu-ray player, it connects after about 15-20 secs and plays only first 25-30 secs and then stops and continues again after 5-10 secs. This cycle continues. Again there is some issue here!!!
Request you to check on these issues, if possible.
Thank you once again.
Merry Christmas to you as well.
