fremske
Dec 12, 2013Guide
Request: Java SE Embedded 7 for ARMv7
Hello respected add-on developers, I would like to request: Java SE Embedded 7 for ARMv7 (ReadyNAS 102,104), see link: http://download.oracle.com/otn/java/ejre/7u45-b15/ejre-7u45-fcs-b15-linux-ar...
chirpa
Dec 13, 2013Luminary
Genie+ Marketplace depends on openjdk-6-jre-headless, which currently is version 6u27. Will your Serviio run with that version?
There is also a package for openjdk-7-jre-headless, so you could try 'apt-get install openjdk-7-jre-headless' from an SSH terminal to the NAS. That is version 7u25. The Local Upload option in the GUI does accept .deb files. So you could try downloading and installing this one: http://security.debian.org/debian-secur ... _armel.deb
- Aug 31, 2022Retired_Member
