beezer
Jun 02, 2017Apprentice
Bad Embedded Web Server
Have multiple NETGEAR WiFi routers in office. Prefer to use the office DNS to access them for obvious reasons (e.g., 'PetersWifi' instead of trying to remember IPv4/6 internal addresses like '192.168.245.22', especially since DHCP occasionaly changes the addresses). Unfortunately, calling the embedded admin page on the R7800s by name produces '404' or a bad page (a single digit, usually '0'). The R7800s work if I use the net local IP (sends me to admin login popup). All the other routers (e.g., the R6300s) work as expected regardless of using name, IPv4, or IPv6. Updated to firmware V1.0.2.28, but still fails.
90 day support (these are new routers) requests have produced nothing but a run-around, disrespect, insulting answers ('The Interenet is not available in AP mode.') and refusal to take documentation of the problem. They posted the report to the support web app with the title 'Unable to access the genie page using routerlogin.net' -- so it appears that their '2nd level support expert' doesn't understand basic networking concepts. So i turn to the community for help... anyone?
two WIFI access points on this network. One is called “R6300v2” and the other is called “R7800”:
log onto the R6300 using its name and a browser, like so:
Which gets me to the web interface:
on the Nighthawk, here’s what happens:
But it WORKS when I just use the IPv4 address:
Netgear have fixed this in the webserver firmware! I tested the beta, it works; look forward to release.
- netwrksMaster
Can you do an nslookup on any of the AP's?
- beezerApprentice
ugh. I uploaded imaes of the NSLOOKUPS, the successful web page from R6300v2.xxxx.local, the failure or web page R7800.xxxx.local, and the successful webpage using the IP for R7800.xxxx.local (192.168.254.24). Do you know how to get the pics in my post to show to people who are not logged in as me?
- netwrksMaster
Any images posted have to approved by a mod first. Anyway, I would give the r7800 a static ip then see if it resolves by hostname.
EDIT: can see your images now.
