fremske
Dec 12, 2013Guide
Request: Java SE Embedded 7 for ARMv7
Hello respected add-on developers, I would like to request: Java SE Embedded 7 for ARMv7 (ReadyNAS 102,104), see link: http://download.oracle.com/otn/java/ejre/7u45-b15/ejre-7u45-fcs-b15-linux-ar...
fremske
Dec 16, 2013Guide
Hi Chirpa,
Thanks for your reply. Which is very helpful!
However do you know if the below packages are available for the ARM Readynas 102/104 to run Serviio?
Linux users need to install the FFmpeg package (incl. libRTMP, libASS, libx264 and libmp3lame) for their OS distributions or, ideally, compile FFmpeg using the source files.
Please let me know.
Thank you,
Fremske
Please let me know.
Thank you,
Fremske
- Aug 31, 2022Retired_Member
