networkn
Dec 16, 2012Aspirant
Require more capacity
Hi There! I have a Ultra 2+ with 2 x 2TB Drives which are on the HCL. I don't see any 4TB Drives on the HCL for that device and we really need around 4TB Storage. My options are to find out if t...
mdgm-ntgr
Dec 16, 2012NETGEAR Employee Retired
Some users have found 4TB disks to work but YMMV. If you have issues and you are using drives outside the compatibility list NetGear can and will deny support
