networkn
Dec 16, 2012Aspirant
Require more capacity
Hi There! I have a Ultra 2+ with 2 x 2TB Drives which are on the HCL. I don't see any 4TB Drives on the HCL for that device and we really need around 4TB Storage. My options are to find out if t...
Dec 17, 2012Guru - Experienced User
Personally I would avoid the Seagate. Search the forums here for "ST3000DM001" and read through the posts.
When replacing drives with XRAID2/single redundancy you have to replace one at a time, and wait for full resync before replacing the next. I do this with the NAS running. It should expand to 3 TB after the second drive resyncs.
It's always a good idea to update your backup before replacing/adding drives.
