networkn
Dec 16, 2012Aspirant
Require more capacity
Hi There! I have a Ultra 2+ with 2 x 2TB Drives which are on the HCL. I don't see any 4TB Drives on the HCL for that device and we really need around 4TB Storage. My options are to find out if t...
networkn
Dec 18, 2012Aspirant
Etz wrote: It really depends what features you are actually using, but there will be also performance difference... :wink:
Sorry I don't understand what you mean by also performance? Is there some sort of benchmark I could refer to?
Basically I use a nas as a device to storage backups onto and then we copy from the nas to usb and take offsite. I want file copies to be pretty reasonably quick.
