networkn
Dec 16, 2012Aspirant
Require more capacity
Hi There! I have a Ultra 2+ with 2 x 2TB Drives which are on the HCL. I don't see any 4TB Drives on the HCL for that device and we really need around 4TB Storage. My options are to find out if t...
Dec 18, 2012Guru - Experienced User
The ultra 4 plus is fully compatible with your ultra 2, so you can migrate the disks over.
The NV+ v2 is a completely different platform, with a newer management interface. It is a bit slower than your current NAS, and the feature set is somewhat different. There is a comparison chart here: http://www.netgear.com/images/ReadyNAS_ ... -57079.pdf
CNET measured the ultra (not the ultra plus) at 875 mbits/sec read and 444 mbits/sec write (http://www.cnet.com/network-storage/net ... 013-2.html)
They also measured the nv+ v2 at 658 mbits/sec read and 304 mbits/sec write (http://www.cnet.com/network-storage/net ... 084-2.html) Note that I changed the units in this review from megabytes to megabits.
So that would say that the NV+ V2 is 2/3 to 3/4 of the performance of the ultra. And of course the ultra plus is somewhat faster than the ultra.
