Squazz
Aug 19, 2015Aspirant
Restyling admin area
I have a ReadyNas pro 4 with OS4. Is it in any way possible to restyle the admin area? I can handle the styles myself, but I'm not quite sure if it's possible to replace the CSS files on the Re...
Aug 19, 2015Guru - Experienced User
Perhaps consider shifting to OS 6???
- SquazzAug 19, 2015Aspirant
But, I cannot upgrade my firmware? It tells me that I'm running the latest firmware?
- StephenBAug 20, 2015Guru - Experienced User
Well, you can - although its not supported.
There are instructions here, but you need to search for them. The process is destructive, so you would need a full backup (and restore your data afterwards).
- DaneAAug 20, 2015NETGEAR Employee Retired
Hi Squazz,
Just a few questions below:
a. What is the current firmware version of your ReadyNAS Pro 4?
b. What changes would you like to implement on the current appearance of the web-GUI of the ReadyNAS Pro 4?
If ever you are capable on making such changes on the web-GUI of the ReadyNAS Pro 4, please be reminded that it might affect the functionality of the NAS itself.
As per StephenB's suggestion, let me share this forum link below if ever you want to consider installing OS6 to your ReadyNAS Pro 4. Take note of these few important reminders:
a. You need to have full backup of your current data stored in your NAS.
b. Bear in mind that you will not get any assistance from Netgear Support. However, you could post and search here on the community for your future concerns.
DaneA
Netgear Community Team
Yes. "Unsupported" means exactly that.
And if you change the admin UI and break something, then you are also in unsupported territory.
It would be useful to understand what you want to change and why.
