PeterD2
Oct 31, 2024Aspirant
Retrieving data from an ancient ReadyNas
Hi all, I have a very old ReadyNas Duo that I would like to retire, but I urgently need to remove and safeguard the data from it. It will boot and the device is visible on the network, but I cannot ...
PeterD2
The first part (enabling SMB) didn't work. The second one I have no idea what that is. I downloaded something called RLinux6_i386.deb but I don't know how to open it. I've never even seen Linux in operation so I don't know what to do with it. The drive does work inside the case as a SATA device, and using a partition program I can see the partitions but that's as far as I can go.
I can "download" individual files if I enter 192.168.1.9 and log in with my credentials, but it comes up in a browser window, not under This Computer. I cannot download folders in this manner. The device does show up as a Storage device but I cannot access it.
Entering \\NAS just returns an error, and the IP address opens it in a browser.
PeterD2
And in answer to your other question, I thought I had the admin credentials, and I know I set my account as an admin, but I don't know how to get in to the admin console. I cannot get RAIDar to work, despite installing two or three different java drivers it says it is missing. I'm starting to panic now.
- StephenBOct 31, 2024Guru - Experienced User
No need to panic yet.
If you are running the old 4.3.8 RAIDar, then you can get a working java version from here:
If you are running RAIDar 6.5 then get the newest one from here:
You don't actually need RAIDar to reach the NAS admin console. You do need to use FireFox and change a security setting in order to reach it. Otherwise you get the "ERR_SSL_VERSION_OR_CIPHER_MISMATCH" that you posted in your screenshot. So download FireFox, and then set security.tls.version.min to 1 (browse to about:config and search for the setting). After that just enter https://192.168.1.9/admin in your browser. The username has to be "admin". If you can't get in, post back. There is a way to reset the admin password.
Can you give more details on what went wrong when you tried to access the NAS after turning on SMB 1.0/CIFS? Once you know the NAS admin password for sure, I can give you some commands that should mount the NAS data volume to a PC drive letter.
On R-Linux, you downloaded the Linux version. You should have downloaded the Windows version. There is a windows tab in the upper right of the web page that you need to select - easy to overlook. Again, that software will require you to attach disk 1 of the NAS to the PC. If you try it, power down the NAS before removing the disk, and keep it powered down until you replace it.
