wetmarble's avatar
wetmarble
Looking for ancient firmware for GS724T v3
I have an old GS724T v3 that is on firmware V1.0.3_30. I would like to bring it up to the latest firmware (5.4.2.30). In searching the forum, I see that is recommended to update the firmware incrementally, but the earliest version of firmware that I can find is 4.2.1.9.
Does anyone know where I can find earlier firmwares?
Thanks in advance,
Adam
  • A GS724T with V1.0.3_30 is very unlikely a V3 model. Much more this firmware and model can not even be discovered on the SmartControlCenter.Insttwd the even more legacy Smartwizard Discovery needs to be used. This will unveil it's a V2
    What exactly does the product label on the underside show?
  • schumaku's avatar
    schumaku
    • wetmarble's avatar
      wetmarble
      The label indicates it is v3. I have attached a photo.
        wetmarble
        The settings indicate firmware V1.0.3_30 as per the attached screenshot. The top shows SmartWizard Discovery. The bottom shows the settings from accessing the switch in a browser.
        As you predicted, the switch is not discoverable in SmartControlCenter.
        Any idea what's going on?
ProSupport for Business
