rogjack's avatar
rogjack
Guide
Apr 22, 2017
Reusing a NAS disk in a PC
I have a 4GB disk that I have removed from a ReadyNAS 104 and I would like to install into a PC. I don't seem to be able to format the disk in any way that will regain all its space, there appear to ...
  • rogjack's avatar
    Apr 26, 2017
    I have now found the problem, it was the USB hard drive caddy that I use to transfer from one machine to another. It doesn't seem to like drives over 1.5GB in capacity and gets really confused. I have now replaced it with a new USB3 enclosure and it sees the entire capacity of the drive and NO protected windows partitions. I think the old enclosure was misreading the drives and interpreting the results incorrectly.
    Thanks to everyone that replied, I got a lot of new information and a couple of useful utilities so that's a gain :)
ProSupport for Business
