M4cc45
Nov 13, 2012Tutor
Revise ReadyNas remote to create full VPN
Or even a partial one so that I can access web interfaces on the NAS (especially ones on different ports). Having a remote connection is great but if I can only access shares which I've permissione...
Nov 19, 2012Guru - Experienced User
I use port forwarding to get to the NAS, and also have port forwarding to my PCs. Then I use the WoL add-on for the Pro to wake up the PCs as needed. My connections are all encrypted.
It would be simpler to have a full VPN tunnel terminated in the NAS.
