brandxlb
May 26, 2020Aspirant
RN 214 external USB HDD keeps disconnecting
Recently the external Seagate Desktop Backup 6TB USB HDD I use for backing up the RN214 (firmware 6.10.3) keeps apparently randomly disconnecting and then reconnecting. I've changed USB leads and s...
brandxlb
May 27, 2020Aspirant
OK so looks like I need a replacement RN214. If I get a replacement, is there a way to simply configure the new unit exactly as the old unit before I plug in the drives from the old unit? (ie shares, users, backup schedule, apps etc)
Sandshark
May 27, 2020Sensei
The configuration moves with the drives. Just be sure to move them with the power off. What's in flash on the NAS only passes control to the OS on the drives except when initializing a new NAS.
If your replacement NAS is an Intel one (300 series or better), then you should un-install any apps on the 214 and then re-install them once you have migrated the drives.
