TimMcMichael
Jan 18, 2023Aspirant
RN 424 - Excessive space consumed by Snapshots
I was running out of space on my ReadyNAS 424, so I backed up the data to another device and deleted a considerable amount of data. My current stats are Total space ~3TB with Data at 246 GB, Free Sp...
Sandshark
Jan 18, 2023Sensei
On the Shares tab, right-click on the gear icon of a share that has snapshots you want to delete and select Recover. Then right-click on the snapshot you want to remove and select Delete. If no snapshots are showing up, then you'll need to go in via SSH and delete them (with more instructions from here). Note that it make take a little time for the NAS to recover the freed space.
If you have a lot of "file churn" on your NAS, and especially if you also have defrag turned on, then that can lead to excessive space used for snapshots. The default "smart" snapshots can also be an issue, as they retain monthly snapshots forever. Going to custom snapshots and specifying a retention time can help a lot.
TimMcMichael
my snapshots are not showing up in the GUI. Your post did not list the way to force it via SSH. Can you post those? Thanks.
- SandsharkJan 18, 2023Sensei
Sometimes, this will work:
touch /.force_snapshots_upgrade systemctl restart readynasd
If it doesn't, then you have to go into SSH and specifically delete the snapshots. See StephenB's response in this thread: https://community.netgear.com/t5/New-ReadyNAS-Users-General/Could-not-delete-share-due-to-snapshot-deletion-failure/m-p/2238160/highlight/true#M49039
