NeBla
Jul 08, 2019Aspirant
RN DUO v1 - Power Glitches - SMART Information for Disk 2 - SATA reset
Hi Commuity Folks, Got a question looking for some confirmaitn i'm understanding the situation i see correctly. I have an older model ReadyNAS Duo V1 (been a great device - running for many year...
- Jul 17, 2019
Hi okay thanks for the those points.
By the way the cause of the power glitches was a faulty power pack...
So my ReadyNAS lives on :)
Jul 09, 2019Guru - Experienced User
NeBla wrote:
Re migrating, is that cause the disk are not compatible? or the storage format used inst upward compatible?
There are a couple of reasons. One big one is that the Duo uses an old sparc CPU, and the RN200 uses a completely different arm CPU. So the RN200 would need to completely replace the OS partition on the drives. And the new OS partition is 4 GB - while the one on your Duo is only 2 GB. So the sizes don't match.
In addition, the file system on the data volume uses btrfs on the RN200 series. The Sparc uses ext.
NeBla
Jul 17, 2019Aspirant
