semola1
Apr 21, 2020Tutor
RN102 - Disk Upgrade
Hi all, I need to upgrade my NAS changing the actually 2x4Tb disks with 2x6Tb or more. For changing disk can I change one drive at a time and wait for the realignment/rebuild of system? Than...
- May 08, 2020
Of corse. The fan has become noisy as a result of the numerous times that I have cleaned it from dust.
I will look for a fan with equal revolutions and, if possible, greater CFM
Thanks
Sandshark
May 08, 2020Sensei
If you replace the fan, be sure you get one with similar RPM and CFM ratings. Of course, that typically means that it's going to be about as noisy as the original unless there is something actually wrong with yours.
semola1
May 08, 2020Tutor
Thanks
- SandsharkMay 08, 2020Sensei
If you clean the fan with compressed air, you should use something to keep it from spinning. Otherwise, the bearings can be damaged. I don't think the stock fan has ball bearings, so you might also look for that, if you can find them in an otherwise compatible fan.
