dobbsy
Mar 07, 2016Aspirant
RN102 Power Light Flashing and unable to acess
Hi Everyone, Recently my nas has starting acting up. When the NAS starts up from its scheduled time, the power light flashes all the time and I’m unable to log into it from the cloud or via Raida...
Mar 07, 2016Guru - Experienced User
If you are running 6.4.1 or 6.4.2, then the first thing to do is disable the antivirus service (system->settings). There is a known issue there that is crippling performance.
dobbsy
Will try that first,
Do you need to have an antivirus program installed on them ?
- StephenBMar 07, 2016Guru - Experienced User
No. Just log into the web ui, and go to system->settings. If the AntiVirus service button has a green stripe it is enabled. Click on it to disable it.
- dobbsyMar 14, 2016Aspirant
Thanks will try it
