tytou
Aug 26, 2015Aspirant
RN102 self power on monthly
I've bought a ReadyNAS RN 102 a year and half ago, and since the begining it self powers-on on the 26th of each month at 7AM French time. I've never set any configuration for this (auto power-on/ shu...
mdgm-ntgr
Aug 26, 2015NETGEAR Employee Retired
Did you buy it second hand?
The power on schedule is not cleared on factory reset on the RN102. It won't show in the UI, but it will still be configured.
Perhaps configure the power schedule (don't forget to apply your changes), reboot the NAS and then turn it off again.
- tytouAug 26, 2015Aspirant
Hello,
Thanks for you answer. I bough the NAS as a brand new one, not a scond hand.
I'lll try to activate/deactivate with rebooting and see f it works. I'll keep you informed, but I may need to wait for 26th of September ;)
Rgds,
Tytou
- tytouAug 31, 2015Aspirant
I did configured the 'power schedule', rebooted, and waited to NAS to power on. I have then reset the power schedule to 'disabled' and rebooted. But, if this is the issue, then, I'm confused because I've not seen any way to tell the NAS to power on on the 26th day of each month... Let's wait Sept. 26th and see...
Rgds,
Tytou
